We have updated the encryption process in Netwrix Data Classification 5.7.10.1 to improve its performance across Distributed Query Server (DQS) environments.
What’s Changed in Netwrix Data Classification 5.7.10.1.
DQS encryption and synchronization update
We’ve revamped NDC’s encryption process to deliver smoother, more reliable performance across Distributed Query Server (DQS) environments. The new approach reduces cross-instance encryption errors and cuts down on the configuration work required. NDC servers within a DQS environment no longer require to be joined to a domain, and it is no longer necessary to run NDC as a domain account.
New NDC instances now join the DQS automatically during installation, ensuring consistent setup from the start. Because of this centralized model, they can’t connect to databases created for standalone deployments unless DQS is enabled.
Bug and security fixes
| Description | Case # |
| Fixed an issue with redaction workflows failing due to duplicate regex matches | 401422 |
| Added support for OCR Page Segmentation Modes | 379714 |
| Fixed file shares not being correctly excluded by source watcher and file exclusions | 364517 |
| Fixed an issue with classifying numeric sequences containing whitespace characters | 389700 |
Need help with this update?
| Situation | Action |
| If you have a question you’d like to ask other experts… | Create a discussion in the community: Data Classification > Data Classification Discussions & Questions |
| If you have a feature request… | Let our product team know directly: Data Classification > Data Classification Ideas |
| If you have something cool to show… | Show everyone what you built: Data Classification > Data Classification Show & Tell |
What are your thoughts?
