Copying a password to another organisation unit
copying a password to another organisation unit should be possible
Copying a password to another organisation unit should be possible. If you copy (duplicate) a password it is not possible to save it directly into another OU. You have to move it afterwards. There should be anoption to select the target OU, like it is possible when you create a new password.
duplicate + move the password;
sometime (depends on permissions) a copy & paste session for every password item;
