Control path analysis - seeing the entire path
When using the control paths anaysis, is there a way to see the entire path istead of the truncated path ?
I understand that bloodhound is an option - but given that the data appears to have been gathered by Pingcastle - then truncated - im wondering if it is available somewhere else outside of the html report ?
Have you found the visualization like this old example:
Source: Delegation vulnerability - PingCastle
Maybe this way “Control Paths Analysis” → “Admin groups” → scroll right in the table to “Detail” and select “Analysis” where you have at least one “Indirect control”
Depending on the case disable the checkboxes on the left.
Take a look at the message on objects and connecting lines when waiting for half a second.
Thanks very much - i never realised that was there!
