Exporting Full Permission Paths for High-Privileged Groups
The customer has requested the ability to export full permission paths for all high-privileged groups into Excel. This would allow them to perform comprehensive analysis across dozens of domains and identify patterns or anomalies in how permissions are granted, ensuring alignment with their intended design.
As per our Product Team, you can use the Analysis button:
https://www.pingcastle.com/PingCastleFiles/ad_hc_test.mysmartlogon.com.html
- Navigate to Control Path Analysis → Admin Groups → Details link (shows EVERYONE in it).
- To see the full path, click on Certificate Publishers or the Analysis link and review the details.
- You can also hover over each part of the chart for additional information.
What’s not feasible about the workaround:
While this method works, it can be challenging in larger environments because the chart doesn’t provide a straightforward way to analyze permissions across many domains and groups. Exporting directly to Excel is currently not feasible.
Any insights or workarounds would be much appreciated.
Just a quick export of the XML using “ImportExcel” module (by DFinke) to create an Excel XLSX File.
Example:
Code example that searches the current folder for a “ad_hc*.xml” file and gets some ControlPath Details for creating an Excel file:
$XMLData = [xml] (Get-Content (Get-Childitem ad_hc_*.XML)[0] -RAW)
$i=0
$(foreach ($ControlPath in $XMLData.HealthcheckData.ControlPaths.data.data) {
$i++
$ControlPath.Nodes.Node | Select Id,
Name,
Type,
ShortName,
Distance,
Name="TargetDetails";
Expression={
if ($_.Id -eq 0) {
$ControlPath | Select-Object Name,
Description,
Typology,
ObjectRisk,
NumberOfDirectUserMembers,
NumberOfDirectComputerMembers,
NumberOfIndirectMembers,
NumberOfDeletedObjects,
DirectUserMembers,
IndirectMembers,
Dependancies,
DeletedObjects | Convertto-Json
Name="LinkedToID";
Expression={
$Id = $_.Id;
$ControlPath.Links.Link | where {$_.Source -eq $Id} | Select-Object -ExpandProperty Target
Name="LinkedToName";
Expression={
$Id = $_.Id;
$LinkTargetID = $ControlPath.Links.Link | where {$_.Source -eq $Id} | Select-Object -ExpandProperty Target
$ControlPath.Nodes.Node | Where {$LinkTargetID -eq $_.Id} | Select-Object -ExpandProperty Name
Name="LinkedToHints";
Expression={
$Id = $_.Id;
$ControlPath.Links.Link | where {$_.Source -eq $Id} | Select-Object -ExpandProperty Hints
} )| Export-Excel -Now
That could be a good point to start, depending on the needs. I think this data is difficult to display one per line in Excel if you need more details. In my opinion the “analyze” button in the HTML Report, or something dynamic like that, is way better to understand.
