Compare Environment Enhancements
Platform Governance for NetSuite enhances the usability of the Compare Environment tool:
- Changed the default Comparison Type to Diff (differential)
- Added ability to multi-select Customization Types to compare
- Improved error message descriptions
- Removed the unused Display Non Material Changes Results option
To access this feature:
Open Netwrix > Change Management Tools > Compare Environments
Customization Type
You can now select multiple Customization Types to compare. Use Shift and Ctrl click to select multiple types.
Notes
- Load time increases with each customization type selected.
- NetSuite limitations apply to the number of results. An error message is displayed if there are too many results.
