Bulk Department Reassignment
Endpoint Protector Server
Add the ability to mass update the assigned Department for multiple Endpoint Protector agents directly from the Endpoint Protector Server console.
Our organization manages hundreds of deployed Endpoint Protector agents across multiple locations. During a deployment phase, a large number of agents were assigned to an incorrect Department. Currently, Endpoint Protector does not provide a way to update the Department field in bulk from the management console.
We would like to have a feature that allows administrators to select multiple computers and change their assigned Department through a single bulk action. Ideally, this functionality could be available from the Computers management section, with options to filter devices, select multiple endpoints, and assign them to a different Department.
This capability would significantly reduce administrative effort, minimize the risk of human error, and improve management efficiency when organizational structures change, departments are renamed, or deployment mistakes need to be corrected.
Since the Department assignment is an administrative attribute already managed by the server, a bulk-edit feature would be the most practical and user-friendly solution compared to modifying each endpoint individually.
Currently, the only available workarounds are:
Manually editing each computer one by one through the Endpoint Protector console and assigning the correct Department.
Uninstalling and reinstalling the Endpoint Protector agent with the correct Department configuration.
Both approaches are extremely time-consuming and impractical when managing hundreds of endpoints. They also increase the likelihood of administrative mistakes and create unnecessary operational overhead. A bulk Department reassignment feature would eliminate these issues and greatly simplify endpoint administration.
Hi Alessandro,
Thanks for submitting the request. It aligns with our future plans for console enhancements, so it’s been added to our roadmap. We can’t share an ETA at this point, but we’ll keep you updated here as things progress.
Best regards,
Zoran
