Generally speaking, when should we expect these to be added? I know (and did) download the .zip file and upload them, but then we have ‘multiple’ Edges in the system, which makes it a bit complicated to make/update policy, as we’re referencing multiple “Edges”. Replace “Edge” with “Chrome”, or anything really.
What is the ‘expected’ release of Cloud ADMX updates? And are these release notes anywhere; IE, do they come out with a new .1 release type thing, or are they added into the console ‘whenever’?
We don’t currently have a set scheduled to do this. I try to go in every few months and do a sweep of all of the provided ADMX templates and update what there is to update. If it’s in-between updates and there is something that you need done ASAP, you can always create a ticket for it and we’ll do it for you.
Sorry, I got pulled away on some other tasks which means I’m going to be that jerk that posts a reply towards the end of a Friday afternoon, lol. Is this something that’s testable? Yes. However, grabbing an ADMX file that we’re not using and/or testing on something that’s already in production both seem a little “extra” at the moment, so I’m hoping you already have an answer instead of making us test Here’s the scenario…
Customer uploads Edge ADMX file/policy (CE) because it updated.
Customer creates or updates an EPM/PP LPM Administrative Templates Manager policy (CP) based on CE.
Netwrix updates/uploads the same Edge ADMX file/policy (NE).
Customer deletes CE (because it makes everything cleaner and why have multiple uploads of the same ADMX?).
Does the CP remain unchanged because the ADMX policies/definitions are still present in the customer’s tenant/environment because the NE is still present?
Does the CP bomb out because it no longer has the underlying ADMX policies/definitions are no longer present?
As it is in Group Policy, so it is in the cloud. The ADMX template is just there for a GUI representation of the configuration options. Once the policy is created, it’s no longer required (unless you want to edit it).
Further, it actually doesn’t know where the ADMX file is located, and it doesn’t care. It only knows the path within. Whether it’s Client side or PolicyPak (Endpoint Policy Manager) side, updated or an older version of the ADMX, it doesn’t know or care. As long as the path, setting and options are the same, it will match up.
Thanks, John. That makes sense. In that case… when you, Netwrix, update ADMX files on your end, are they a rip and replace? I’m still thinking of the Edge ADMX files because that makes it easy and can be applied to others. Currently, the Edge ADMX’s display name from Netwrix is “MS Edge - 135.0.3179.66.” Let’s pick a random policy like “Enable the default search provider.” If we create an LPM policy based on that Edge ADMX definition,
then Netwrix updates the Edge ADMX so it now has a display name something like 136.x.x.x, will our previously created “Enable the default search provider” LPM internal policy turn red (uneditable but still applicable)?
Will it remain status quo because of the underlying namespace and filename remaining the same?
I’m sure you can probably see where I’m getting with this… will we need to recreate LPM policies with each updated ADMX file if we need to edit said policy?
Yes, it is a rip and replace. But No, it won’t turn red unless that policy was deprecated (and yes, still applicable).
There is usually very little differences between versions. They usually keep the old configs around for a while. And even if they are deprecated, they’ll quite often put them in a “Deprecated” folder where they are still accessible.
