Add Group Filter to the Effective Rights Criteria Form for CAP Tracking
Extend the Effective Rights Criteria form in Endpoint Protector to include a group filter, so administrators can export a single report showing all CAP applied to computers or users within a selected group.
The Effective Rights section already allows administrators to view applied Device Control and Content Aware Protection policies, with export options filtered by rights, users, computers, and device types. However, it currently lacks the ability to scope a report to a specific group.
In some of our customer, CAP policies are applied at the group level, but individual exceptions, such as allowing one or two machines in a restricted group to transmit files to external vendors, are added at the computer or user level over time. As these exceptions accumulate, there is no efficient way to see which members of a group are operating under different rights than the rest.
Adding a group filter to the Effective Rights Criteria form would allow administrators to select a group and immediately generate a consolidated report showing each member’s effective policy status, with exceptions clearly surfaced. This would significantly reduce audit preparation time, lower the risk of undetected misconfigurations, and give administrators an at-a-glance view of policy drift within any group.
Because the Effective Rights export does not support group-scoped filtering, administrators must manually open and cross-reference individual policies to determine which computers or users within a group have been excluded from the group-level CAP. This is slow, error-prone, and does not scale, particularly during compliance audits where both accuracy and speed are critical.
Hi Denni,
Thank you for the detailed write-up and the mockup — both make the use case very clear. The scenario you describe, where exceptions accumulate at the computer or user level over time and drift from the group baseline, is a real audit challenge and your suggested solution is well-targeted.
The gap you’ve identified is real — the Effective Rights form currently lets you filter by computer, user, device type, specific device, and right, but not by group. We’ve noted this as a feature request and it’s something we’ll be looking at going forward in the mid future.
We don’t have a timeline to share at this stage, but we’ll keep this thread updated as there is progress.
Thanks again for the thorough submission.
