Enhanced Reporting Filters
Enhance the reporting filter capabilities by adding group-based filtering and multi-selection support for computers, users, and events within a single report.
Currently, the reporting pages do not provide sufficient filtering flexibility for operational reporting needs.
For example, when we want to generate a report for users in a specific department such as the HR group, we cannot filter directly by group. Instead, we must manually select each related computer or user one by one and generate separate reports. Afterward, these reports must be manually merged or additionally filtered in Excel/CSV files.
A similar limitation exists for event filtering. If we want to review both “User Login” and “User Logout” events together, we currently need to generate separate reports for each event type and combine the results manually.
We believe the best solution would be to improve the filtering section of the reporting pages with the following capabilities:
Group-based filtering support
Multi-computer and multi-user selection within a single report
Multi-event selection support
Ability to combine multiple filter criteria in one report query
This enhancement would significantly reduce manual work, simplify reporting operations, and improve efficiency by allowing administrators to generate consolidated reports directly from the console instead of relying on external processing.
Currently, we work around these limitations by generating multiple separate reports for each computer, user, or event type and then manually combining or filtering the exported Excel/CSV files.
Dear Faruk,
Thank you for taking the time to share such a detailed and valuable use case for your proposed improvement. We truly appreciate the effort you put into outlining your requirements and explaining the business need behind them.
To let you know, we already have enhancements planned for reporting filters, and your suggestions align well with the direction we are exploring. As part of our ongoing evaluation process, our team will carefully review your feedback and assess the technical feasibility of extending the functionality to include features such as group-based filtering and multi-selection support for computers, users, and events within a single report.
Your input will certainly be taken into consideration as we continue planning future improvements and prioritizing development efforts. Once we complete the necessary technical assessment and determine the final implementation approach, we will be able to share additional details regarding possible timelines.
Insights like yours play an important role in helping us enhance our solution and better meet our customers’ needs—keep sharing your ideas!
We will keep you updated as we progress.
Have a nice day,
Simona
