Hide expired passwords
One-sentence summary of your feature request?
Expired passwords should no longer be used for Autofill or SSO
We have datasets that contain expired passwords. These datasets must be stored for a certain period of time for specific actions.
Unfortunately, these datasets are also used for Autofill, or for an attempt at SSO, which limits the feature and also the overall convenience.
It would be great if datasets where the date under “Valid until” is in the past were no longer shown in the web plugin or during Autofill / SSO.
Right now, I have to select the corresponding dataset manually.
Hi Frank,
Thanks so much for your idea and your feedback—it really helps us. We’re evaluating the proposal and will get back to you as soon as there are any updates.
Best regards
Kristina
