Additional form field for customer number
A new form field that automatically fills in the customer number field.
While I can create a custom field in the form, it is not recognized during autofill. We frequently encounter manufacturer shops that change their login process in this way, and our salespeople are frustrated by having to log in multiple times a day.
For example, see here: Registrierung | Schaffelhuber.
Currently, users have to manually fill in the field when they want to log in as a dealer in a manufacturer shop.
Hello Matthias,
We also often encounter the use case where individual fields on websites are automatically populated using custom fields in forms. The browser add-in allows you to capture the respective application. Afterwards, you can link the desired individual field with the corresponding custom field from the form and save it in the dataset. When the page is revisited, the field will then be automatically populated according to this linkage.
Just a brief note in case you weren’t aware of this feature.
Best regards,
Gausi
