Netwrix Strongpoint for NetSuite 7.6
Netwrix is pleased to announce the general availability of Netwrix Strongpoint for NetSuite 7.6 available for pre-release on January 15th, 2025. To ensure you are using the latest version in all accounts, update the Strongpoint bundle in your sandboxes as we are unable to push updates to them. The upgrade to your production account will be implemented during off-peak hours starting January 22nd.
Enhancement: Code Update to Support NetSuite 2025.1 Removal of the Ext JS Library.
Strongpoint for NetSuite updates all of the scripts and bundles to be compatible with the NetSuite 2025.1 release. The NetSuite release removes the unsupported Ext JS Library. For more information about the need for this change, please refer to Netsuite’s Release Notes for 2025.1.
SoD 1.7
The SoD 1.7 bundle is available in conjunction with Netwrix Strongpoint for NetSuite 7.6. To ensure you are using the latest version in all accounts, update the SoD bundle in your sandboxes after updating to Strongpoint for NetSuite 7.6 as we are unable to push updates to them. The upgrade to your production account will be implemented during off-peak hours starting January 22nd. If you are an Enterprise Customer, we will push the SoD 1.7 bundle.
Bug Fixes
See the Netwrix Strongpoint for NetSuite Bug Fix List for a list of bugs fixed in this version.
