Unable to open Auditor after trial expired
Hello,
Our trial ended, and I am not able to get Netwrix Auditor working anymore.
There is no way to get that thing to some local setting or something. It can only be modified.
What should I do?
Hello,
If your license is expired and the product is switched to “Free Community Edition” mode, you will have a limited list of features.
These restrictions take place while trying to save configuration objects.
Based on the provided information, I think there was an attempt to save a Monitoring Plan where a few email recipients are specified.
Please consider other restrictions as well when configuring and using the product in “Free Community Edition” mode.
Thanks,
Roman
Hello,
I knew about the recipients but as I read your article → I had to also disable audit database and found where. Hoooray! Its working <3
Thank you a lot!!!
Zdenek Skrivanek
