Take parameters values changes into account for manually assigned Role
Parameters values for manual Role must be taken into account even after assignement
A role with parameters can be assigned because the automatic assignment rule is met. If the rule is no longer met (for example: a change in the value of one of the dimensions used), the role is automatically removed.
When assigning a role with parameters manually, the values to be taken into account for each parameter are selected. If any of the values change in the user’s record, the role must be removed. This is not the case. Currently, the role is always assigned. In cases where the role grants access to a resource type, the resource is not deleted; only the scalar rules are. There is no provisioning order for deletion.
The current behaviour needs to change. If any of the values used for a parameter during the manual assignment of a role changes, the role must be removed. The behaviour should be similar to that for roles assigned automatically via defined rules.
To identify the roles to be removed, we use the data extraction feature available on the Assigned Roles page and a report we have created to extract the list of records. We then use Power Query to cross-reference the data.
We could perhaps use the recertification module, but we are not yet familiar with it.
Hi @mathilde.lor
Thanks for submitting your idea. I’m going to meet with the team to see how we can improve this. I might contact you by email to discuss further to make sure we understand your use case.
