Add a standard credential, for example via regexp, for an application
We encounter the problem, that if a user wants to open an ssh/rdp connection via an application, he has to create a password entry with his personal credentials and connect it to an application.
We would like to see a feature, where you can set standard credentials for applications, with for example reggexp. With this, an application has to only be set up once, and every user can user can connect with personal credentials and no further configuration is required.
A current workaround is to create an password entry with the users personal credntials and then create an application, which is connected to the password. Every user has to do this configuration by himself.
