Recently, I received an inquiry regarding the types of traffic that must be permitted through a Web Application Firewall (WAF) to ensure proper functioning of Privilege Secure’s Secure Remote Access Portal. If this pertains to your implementation of Secure Remote Access, please refer to the team’s guidance provided below.
The Secure Remote Access Portal uses fixed API endpoints, dynamically generated front-end asset URLs, and WebSocket Secure (wss://) connections for real-time features. The following WAF rules are required to ensure secure and reliable operation.
API and Authentication Endpoints
Allow the corresponding HTTP methods for these specific routes:
| Route Pattern | Allowed HTTP Methods |
/api/v1/* |
GET, POST, PUT, DELETE |
/signinBody |
POST |
/signin2fa |
POST |
/middlewareHub |
GET, POST |
/images/* |
GET |
/oidcSignin/* |
GET, PUT |
/samlSignin* |
GET, POST |
/samlSigninCallback |
POST |
Portal Front-End Static Asset Routes
The portal’s front-end serves static files from the web root (/). Filenames are minified and versioned per release.
- Allow all GET requests to file paths under
/with typical static file extensions.
Examples:/main.abc123.js/vendor.456def.chunk.js/logo.789ghi.png/styles.1a2b3c.css/assets/fonts/fa-solid-900.woff2/index.html
- Do not restrict GET requests by specific filenames, as asset names change each version.
WebSocket Secure (WSS) Endpoints
Certain endpoints use WebSocket connections (wss://) for real-time communication and updates.
- Allow HTTP GET requests with the
Upgrade: websocketandConnection: upgradeheaders on the following endpoints:/middlewareHub
- Required headers:
UpgradeConnectionSec-WebSocket-Key,Sec-WebSocket-VersionSec-WebSocket-Protocol
- Ensure the WAF does not block, disrupt, or filter upgraded WebSocket traffic on these endpoints.
General Policy Statement
The WAF must allow:
- The specified HTTP methods for all fixed API and authentication endpoints listed above.
- Unrestricted GET access to asset files under the web root (
/), including files with extensions such as.js,.css,.png,.jpg,.svg,.woff2,.ttf, and/index.html. - WebSocket (WSS) upgrade requests on designated endpoints (such as
/middlewareHub), preserving all necessary WebSocket headers and bidirectional traffic.
POST, PUT, and DELETE methods should be limited only to documented API endpoints.
Example WAF Rule Patterns
- Allow
GETrequests (including WebSocket Upgrades) on/middlewareHub. - Allow
GETfor all asset file types under/(such as/*.js,/*.css,/*.png, etc.). - Allow only required HTTP methods for API endpoints as enumerated.
- Dan Piazza (Product Owner - Netwrix Privilege Secure)
