Scripts - Multiple Triggers
Multiple Triggers for Scripts
Pretty simple one! Allow for multiple triggers on Scripts. IE, you have logon. Well, I want logon and unlock. And short of just… making another copy of it, which seems…. awkward? It’d just be nice to have ‘multi select’ on triggers. This would remove duplicate work.
Multiple script entries; IE, if I want a LOGON and UNLOCK, that’s two completely separate entries with ‘the same code’, just different triggers.
So this would be an -OR- and not an and.
If LOGON -or- UNLOCK, then … DO THE THING.
Is that right?
Correct. And yes, I just envision a checkbox/multi select; let me do every single trigger!
Hi Team. Feature added to Productboard
Trying to figure out how that would work actually if you selected every single trigger.
Some things would not be happening at literally the same time, so it wouldn’t make any sense and they would never fire off.
I think because of this we have to consider what things can actually happen simultaneously and not. So this might turn into a bigger picture than initially expected.
