Save Investigation Filters
ability to save and resume various filters configured on the threats investigation dashboard.
the filters are reset which means each time an investigation is required to review threats the user is required to reconfigure any filters.
It would be able to save some time and steps if there was an option to save frequently used filters for the threats dashboard allowing them to quickly select a group of preset filters depending on their needs for reviewing threats.
Keep outside notes of common filters used and manually set them every use.
Hi, in a future release we plan to completely rewrite the threat timeline page. We will consider this feedback when we rewrite it.
Thanks
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
