Request to Display comment in Custom Class Device List
Hello,
We are currently using the Custom Class feature to manage device permissions.
To better track the reason for granting permissions to each device, we add comments for internal reference.
At the moment, these comments are entered in the Friendly Description field.
However, the Custom Class Device List does not display this field,
which makes it difficult to review or identify the reason for specific device permissions.
Therefore, we kindly request that the comment be made visible in the Custom Class Device List.
Kind regards.
It is inconvenient that comments cannot be viewed in the Custom Class Device List,
so we have to check them manually in the List of Devices page instead.
Hi @swma1103,
Thank you for sharing your idea.
We will review this request and get back to you with an update soon.
Kind Regards,
Simona
Hello @swma1103,
Thank you for your patience while we reviewed your request.
We’re pleased to let you know that we’ve decided to move forward with this enhancement. However, at this time, we’re not able to provide a specific delivery timeline.
Rest assured that this request has been added to our development roadmap and will be prioritized as part of our future product improvements.
The feature’s progress can be also tracked on ProductBoard - https://portal.productboard.com/rqqgx2aos1cf9enrezvrre6a/c/513-adding-friendly-description-field-in-custom-class-device-list
In the meantime, we recommend continuing to use the workaround you mentioned, as it remains the best temporary solution until the new functionality is available.
Regards,
Simona
