Reports consolidation sorting should be by numbers rather than by string
If you go to Dashboard => Advanced => Reports Consolidation => Rules Matched
search for a Rule and try to sort “Rationale” the results are sorted by “String” and not as a Number. So after 1 comes 10, 100 , 1090 before going to 11 and finally coming to 2.
If sorted correctly (by numbers) it should be 1,2,10,11,100,1090
N/A
