In the instructions for upgrading an NPS HA pair, it mentions running the NPS HA Config Tool to failover to the secondary node before updating it:
The instructions seem to point to using the NPS.HaMgr.exe that comes with the upgrade installer (25.06.30001). However, when I run that version of the HA Mgr, it does not show the HA replication status properly, it appears to be stuck in a constant refresh of the current state.
If I run the NPS.HaMgr.exe for the currently installed version (4.2.1534), the HA status is reported correctly and active.
Should I be using the “old” version or the “new” version of the HA Mgr tool for the upgrade process?
Thanks.
