Create a report for groups containing nested groups and their membership
Problem: I’m trying to encourage my Team to use GroupID Directory Manager for as many functions as possible. Today there is a report for groups and their members which works fine. This report works great for a group with no nested groups underneath it. Once a nested group is involved the report will only provide the name of the nested group and not provide the membership for those nested groups.
Solution: Create a report that will report on a group and its membership (including nested groups and recursively enumerate the members of any subgroups). This is the best solution as the product already has a report section, it is just missing this report.
Support gave me a powershell script to run. Not everyone on my Team is versed on powershell and there have been errors when running the script.
Will the report called “Groups and number of members with Nesting” address your concern? It shows the number of nest groups and membership count affected. Clicking on the group name should take you to the actual group. when viewing a group, you can see the membership of the group including other groups which further allows you to see that group.
Thank you for the reply. The report you mentioned helps but doesn’t solve the initial issue.
I am looking for a report that will list out the nested groups (including the individual nested group members) underneath the top level group. I don’t really need the count, I need the membership itself showing the hierarchy.
IE. Something similar to the below
TopLevelGroup
-NestedGroupA
–NestedGroupA members
-NestedGroupB
–NestedGroupB members
-NestedGroupC
–NestedGroupC members
-NestedGroupD
–NestedGroupD members
-NestedGroupE
–NestedGroupE members
-Any random directly added Individual group member
