Nested Filtering
Create filters that include ‘and’ per row.
Ability to specify a filter that can only include a subset or exclude a subset of events without having to know all of the exclusions needed.
For example:
Action equals modified AND Details contain ‘index’ AND Who not equal to ‘sqlagent’
Actions other made by the ‘sqlagent’ can still be found.
We have to create exclusions for every unrelated event.
Hello J C,
Thanks for sharing the idea. I want to make sure I fully understand the limitation you’re running into.
Based on your description (for example: Action = Modified AND Details contains “index” AND Who ≠ “sqlagent”), this combination of conditions already reflects how Auditor filters are applied today within a single filter set.
Could you please clarify:
In which UI (Search, Reports, Alerts, etc.) you are configuring this filter?
Whether the issue is related to OR logic between rows, grouping, or filter evaluation order?
A screenshot of the filter configuration and the resulting events list would help a lot.
This will help determine whether this is a missing capability, a UX issue, or possibly a misunderstanding of current filter behavior.
Best regards,
Konstantin
@anon4545
Hi Konstantin,
This would be for creating subscriptions. I honestly no longer remember the use case. Basically, it’s missing exception cases. If I recall, it has to do with events where everything matches except for in some cases a not needs included. Sorry. It’s been so long.
