Manual role assignment: lock by default to calculate end date automatically
Add an option to activate the lock on end date calculation when manually assigning a role
When a role is assigned manually, with the assigned role functionnality or in the permission basket, you are asked to enter the start date and end date of the assignment. There is a lock option that will automatically calculate the end date of the assignment, but by default this lock is inactive.
I suggest to add a configuration option to choose the default value for that lock.
We are always activating the lock manually
Hello @THaudot ,
I think this is configured in your Policy if I’m not mistaken.
Did you have a look there?
It might be inherited from there; on the resource type, you can configure whether you want it to come from the Policy or not. I hope this helps.
Hello @Kamil.Wojenkowski ,
Indeed, that is exactly what I was looking for, thank you for your help!
Best,
Thomas
thanks @Kamil.Wojenkowski for your contribution! :slight_smile:
