Inheritance of permissions - not always understandable
The inheritance of permissions is not always understandable.
e.g.:
If you are working with “predefining rights” and you did not configure one of them as default, permissions will be inherited from the OU or it is set by another “predefining rights” up in the OU tree (if there will be found one with a default setting).
All this is working right, BUT a user is not able to see which permissions will be set in his new password! So there could be a really wrong result. Also there is a possibility to get (more or less) out of the permissions. So you can see, that permissions went “wrong”, but you cannot change it!
Unfortunately already happens at some of our customers…
control it by hand and correct it!
A little tip: We are currently helping ourselves out here with TAG rights templates e.g. “RT_Sales-Standard” (Sales Standard rights template [RT]). But it would be alot better if this would be visible in password secure, without misusing the tags for this purpose.
