Improved OneDCPerDomain HostList
Improve the OneDCPerDomain Hostlist to select a DC from the same subnet as Host/SQL to try and avoid selection of DCs with high latency
Currently the OneDCPerDomain hostlist doesn’t appear to have any logic applied to select a DC close to the main server. At it’s simplest if we selected a DC in the same subnet as the NAA Host / SQL Server it would help avoid slow queries where out of box jobs are set to use the default OneDCPerDomain hostlist
Manually create a list of single DCs per domain that are better aligned to location
I’d suggest going off the AD Site, typically that’s how Windows clients determine DC which may make sense in this use case as well. Even better if it was configurable on how it determines. We have run into this at our clients and one way we get around this is to create a static host list with the DC that we know we can target and successfully connect to which is not scalable and requires maintenance.
Thanks, Andy. I’m marking this as Under Review.
