Introduction
Netwrix Identity Manager (NIM) exposes a complete REST API enabling third-party systems to interact programmatically with the solution. This API is the foundation of advanced integrations: feeding identities from an external portal, triggering workflows, querying the role model, or launching synchronization jobs.
This document is a practical guide intended for presales teams, consultants, and integrators. It covers the entire NIM API usage cycle: activation, authentication, read calls, triggering actions, and best practices.
Typical use cases
- Create or modify an identity from an HR portal or an external ITSM
- Query a user’s permissions in real time
- Automatically trigger an access request workflow
- Launch a synchronization job from an orchestrator (Ansible, Azure DevOps…)
- Export audit data to a SIEM or a dashboard
- Integrate NIM into a Zero Trust architecture for continuous access validation
Key principle:
Any action that can be performed from the NIM web interface can also be performed via the REST API. The API and the UI share the same engine and the same permission rules.
NIM API Architecture
Two exposure points
NIM exposes its APIs from two distinct components:
| Component | Role | Example endpoints |
| NIM Server | Data, role model, workflows, governance | /api/Resource, /api/Job, /api/Workflow |
| NIM Agent | Local actions on the client IT system (provisioning, jobs) | /api/Job/Launch, /api/Agent/Status |
In a SaaS architecture, the server is hosted by Netwrix and the agent is installed on the client’s network. Traffic is always initiated from the agent to the server (outbound only). The server API is accessible from outside; the agent API is only accessible from the internal network.
Swagger Interface
The interactive API documentation is available via Swagger. It lets you browse all endpoints, test calls live, and download the OpenAPI definition in JSON format.
- Swagger URL: [your NIM instance URL]/swagger
- OpenAPI definition (JSON): [URL]/swagger/{version}/swagger.json
- Anonymous access to the page, but each call requires authentication
Activation required
The Swagger interface is disabled by default. It must be explicitly enabled in the ‘Swagger settings’ section of the NIM server’s network configuration. Do not expose it in production without appropriate access control.
Authentication
OpenID Connect Protocol
The NIM API is secured by the OpenID Connect (OIDC) protocol. Each client application must be registered as an OpenIdClient in the NIM XML configuration, with an identifier (clientId) and a hashed secret.
The NIM server’s OIDC configuration is accessible at:
GET [URL NIM]/.well-known/openid-configuration
Declaring an OpenIdClient
In the NIM XML configuration (configuration file), declare a client as follows:
<OpenIdClient
Identifier="MyApplication"
HashedSecret="[secret hash]"
DisplayName_L1="API Client - External Application "
Profile="Administrator" />
<!-- For a profile restricted to a specific scope: -->
<OpenIdClient
Identifier="HRApp"
DisplayName_L1="HR Connector"
Profile="HROperator" />
- The plaintext secret is never stored in NIM, only its SHA256 hash
- Generate the hash with the utility: Usercube-New-OpenIDSecret.exe
- Each clientId must have a dedicated profile (principle of least privilege)
Obtaining an access token
The client_id to use in OIDC calls is the concatenation of the application’s identifier and domain:
client_id = "MyApplication@mycompany.usercube. com "
Call to the token endpoint (client_credentials flow):
POST [URL NIM]/connect/token
Content-Type: application/x-www-form-urlencoded
grant_type=client_credentials
&client_id=MyApplication@mycompany.usercube.com
&client_secret=MySercretClearText
&scope=usercube_api
Response (JSON):
"access_token": "eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...",
"token_type": "Bearer",
"expires_in": 3600
Then use this token in the Authorization header of each API call:
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Via Swagger
If you are already logged in to the NIM application in the same browser, authentication in Swagger is automatic via the session cookie. Ideal for interac t i ve testin g.
Query language — squery
NIM has a proprietary query language (squery) used in the query parameter of GET calls. It lets you express precisely the data you want: column selection, filters, joins, sorting, pagination.
Refer to the official documentation for more details: API query grammar | Netwrix Product Documentation
Postman Configuration: Step-by-step Demo
Postman is the recommended tool for testing and documenting NIM API calls. Here is the complete procedure for setting up an operational Postman environment.
Create a Postman Environment
- Open Postman > Environments > New Environment
- Name the environment: “NIM - [Client name]”
- Create the following variables:
| Variable | Example value | Description |
| nim_url | https://mycompany.usercube.com | Base URL of the NIM instance |
| client_id | MyApplication@mycompany.usercube.com | Full OIDC client_id |
| client_secret | (plaintext secret) | Secret generated with New-OpenIDSecret |
| access_token | (auto-filled) | JWT token obtained after auth |
Obtain the token (Pre-request Script)
In a Postman collection, add a Pre-request Script at the collection level to automatically obtain and store the token:
const tokenUrl = pm.environment.get('nim_url') + '/connect/token';
const clientId = pm.environment.get('client_id');
const clientSecret = pm.environment.get('client_secret');
pm.sendRequest({
url: tokenUrl,
method: 'POST',
header: { 'Content-Type': 'application/x-www-form-urlencoded' },
body: {
mode: 'urlencoded',
urlencoded: [
{ key: 'grant_type', value: 'client_credentials' },
{ key: 'client_id', value: clientId },
{ key: 'client_secret', value: clientSecret },
{ key: 'scope', value: 'usercube_api' }
}, (err, res) => {
pm.environment.set('access_token', res.json().access_token);
Configure Authorization
- In the collection settings: Authorization > Bearer Token
- Token: {{access_token}}
- All calls in the collection will automatically use this token
Test a first call
GET {{nim_url}}/api/Resource/Directory_User?squery=select Id,FirstName,LastName,Email pagesize 5
Headers:
Authorization: Bearer {{access_token}}
Accept: application/json
Error handling
| HTTP Code | Meaning | Corrective action |
| 400 Bad Request | Invalid parameters or missing data | Check the request body and required fields |
| 401 Unauthorized | Token missing or expired | Renew the token via /connect/token |
| 403 Forbidden | Insufficient permissions | Check the profile permissions associated with the OpenIdClient |
| 404 Not Found | Resource not found | Check the resource identifier |
| 429 Too Many Requests | Rate limit reached | Implement an exponential backoff |
Useful Resources and Links
| Resource | URL / Reference |
| Official API documentation | API | Netwrix Product Documentation |
| squery syntax | API query grammar | Netwrix Product Documentation |
| Postman how-to | Request Usercube's API via Postman | Netwrix Product Documentation |
| OpenIdClient XML config | docs.netwrix.com/docs/identitymanager/saas/integration-guide/toolkit/xml-configuration/access-control/openidclient/ |
| Security certifications | trust.netwrix.com |
