How to create an AD connector?
Once Netwrix Identity Manager has been installed with the IGA Core Solution acceleration method, identities are loaded and adjusted with the repositories.
In the majority of projects, the Active Directory connector is often the first, as it manages the accounts and rights of the many linked applications, as well as retrieving the authentication accounts used by SSO, among others. In fact, this connector needs to be set up quickly. To speed up setup, Netwrix Identity Manager lets you use an AD template connector, which you can then adapt to your customer’s needs.
Here’s a quick and easy AD connector installation guide from our training sessions: How to create a AD connector.pdf (1.8 MB)
We look forward to your feedback.
