Fallback MFA instead of MFA reset
Using a second MFA Method when the first isn’t available, instead of resetting the whole MFA Method for the user
We’re using a Yubikey as a MFA method. But what happens when you loose your Yubikey or it happens to be not around you. We would like to use OpenOTP as a Fallback Method if this happens. Or any other MFA method available.
You need to reset the MFA method for the user.
Hi Sascha,
Thanks for your suggestion! We’ve noted your idea of using a second MFA method as a fallback and will make sure the team takes a look at it. We’ll update you once we have more information on how we can move forward with this.
Thanks again for bringing this to our attention!
Best,
Kristina
We would be interested in that aswell, what is your status to that @Kristina.kaya
We do use TOTP as second factor and would be interested in a fallback as well.
One idea would be to allow admins to give users a one-time-use shortcut, instead of resetting to whole MFA.
For now we do work with a workaround - setting the IP of the users device on the IP Filter list via Admin Client and database settings. However, this is a bit time consuming to pull off and can only be done by database-admins.
Could a one-time-password with email work?
