Customization of certification campaigns Options – Reset Feature Accessibility
We request the ability to make the Reset feature available to certifiers without displaying the other unnecessary options.
During certification campaigns, the “…” function currently includes the Reset feature along with several other options. As most of these options are not relevant to certifiers and may cause confusion, we would like to request the following:
The ability to hide the unnecessary “…” options for certifiers, while still allowing access to the Reset feature.
Ideally, we would like either the capability to select which options are available to certifiers, or the implementation of a dedicated button for the Reset feature.
At present, we do not have a viable workaround for this issue. As a result, the Reset option is currently being hidden from certifiers.
Hi @samy.aliahmedmagid
Thanks for your submission, we are reviewing this to see if we can include it in an upcoming release.
