Custom Keyword Not Detected in CAD drawing PDF embeded file type
Endpoint Protector Client
We need to detect CAD drawing PDF embeded files using a custom keyword detection.
We need the ability to detect CAD drawing PDF files that contain embedded files or attachments using custom keyword-based detection in Netwrix Endpoint Protector.
CAD drawings are often converted to PDF for sharing, review, or documentation. These PDFs may also contain embedded CAD files, drawings, project documents, or other attachments. Although the outer file is identified as a PDF, the embedded content may contain sensitive engineering information that needs to be protected.
Currently, detecting the PDF based only on its file extension may not be sufficient to identify whether it contains a CAD drawing or embedded sensitive content.
Why This Is the Best Solution
A content-based detection approach would provide more effective protection than relying solely on file extensions. A CAD drawing can be renamed, exported to PDF, compressed, or embedded within another document, making extension-based detection less reliable.
Custom keyword detection would also give organizations the flexibility to define their own CAD-related identifiers and adapt the policy to different projects, customers, and engineering environments.
Expected Benefits
Detect CAD-related PDF files based on their content.
Detect sensitive information contained in embedded files or attachments within PDFs.
Allow administrators to configure custom keywords and keyword combinations.
Protect engineering drawings and intellectual property from unauthorized transfer.
Provide more accurate DLP detection than file-extension-based rules alone.
Reduce the possibility of sensitive CAD information being transferred through removable media or other controlled channels.
Provide organizations with greater flexibility to create policies specific to their business and engineering requirements.
Note: Additionally kindly review support ticket 00482036.
Currently, we do not have any specific control or detection mechanism for CAD drawings embedded within PDF files.
Hi @Krutik ,
Thanks for submitting this. To help us investigate, could you share a few sample PDFs that contain the embedded CAD files, along with the custom keyword you’re trying to detect? Please remove or replace any sensitive content first.
If you can’t upload them here on the Community, you can send them through our Technical Support team and mention this post. We’d love to look into it.
Thank you,
Zoran
Hello Zoran,
Kindly refer to support ticket 00482036 for the CAD file that has already been provided.
Hi Krutik,
I found the ticket and managed to pull a sample file. We’ve logged this request for further investigation and we’ll keep you posted when we have any updates.
Thank you,
Zoran
