Bulk-Adding Proxied Database Devices with add-sql-proxied-devices.ps1
Applies to: Netwrix Change Tracker (Gen7 API)
Script files: add-sql-proxied-devices.ps1, gen7-utilities.ps1, add-sql-proxied-devices.csv
Adding proxied SQL Server or Oracle database devices to Change Tracker one at a time through the UI is slow when you’re onboarding dozens or hundreds of databases at once. add-sql-proxied-devices.ps1 automates this by reading a CSV file - one row per database - and registering each one as a proxied device through the Change Tracker API.
Despite the “sql” in the filename, the script supports both SQL Server and Oracle databases. The name is a holdover from the script’s original scope; it now builds the correct connection string for whichever DatabasePlatform you specify per row.
This article covers:
  • What the script does and how it works
  • The four connection string scenarios it supports (SQL Server standard, SQL Server Windows Authentication, Oracle direct, Oracle TNS)
  • CSV field reference
  • Step-by-step usage instructions
  • Verifying results in the Change Tracker UI
  • Common troubleshooting tips
Use cases
This script is a good fit when you need to:
  • Onboard a batch of databases during initial deployment - e.g., a customer with 50 SQL Server instances and 20 Oracle databases across several proxy agents.
  • Standardize how databases are added - the CSV forces consistent field entry (credential keys, group names, connection types) instead of manual UI entry that’s prone to typos.
  • Re-run the same registration after a CSV update - useful when a customer sends you a spreadsheet of database inventory and you need to translate it into Change Tracker devices with minimal manual work.
  • Mix connection types in a single run - SQL Server (standard or Windows Authentication) and Oracle (direct or TNS) rows can all live in the same CSV; the script figures out the right connection string per row.
It is not intended for editing devices that already exist - it only calls the agents/register (create) endpoint. Running it twice against the same DeviceName will show and error.
How it works
For each row in the CSV, the script:
  1. Looks up the named proxy agent (ProxyAgentName) via the Change Tracker API to get its AgentId. Lookups are cached, so if 50 rows share the same proxy, only one API call is made for that proxy.
  2. Builds the correct ConnectionString based on DatabasePlatform, ConnectionCredentialType, and a few platform-specific flags (see below).
  3. Resolves any GroupNames from their display name to their internal Change Tracker name.
  4. Calls POST /agents/register to create the device as a proxied database, attaching it to the resolved groups.
  5. Prints a per-row result and a final summary (Total, Success, Failed).
Sample run:
Connection string scenarios
The script builds one of four connection string formats depending on the CSV row. This is the part of the script most likely to need explaining to a customer, so it’s worth understanding each case.
1. SQL Server - standard (SQL login)
Used when DatabasePlatform = SqlServer and WindowsAuth is False or blank.
Server=<IPAddress>;
Server=<IPAddress>,<Port>;
Server=<IPAddress>,<Port>; <AdditionalParameters>
  • Port is only included if Port is populated in the CSV.
  • AdditionalParameters is optional free text appended after the server clause - e.g. ApplicationIntent=READONLY; for an Always On read-only replica.
  • Authentication uses the SQL login stored in the credential referenced by CredentialKey.
2. SQL Server - Windows Authentication
Used when DatabasePlatform = SqlServer and WindowsAuth = True.
Data Source=<IPAddress>;Initial Catalog=<DBName>;Trusted_Connection=True;[TrustServerCertificate=True;]
  • IPAddress holds the SQL Server hostname or IP (or HOST\INSTANCENAME for a named instance).
  • DBName holds the target database (catalog) name.
  • TrustServerCertificate=True; is appended only when the CSV’s TrustServerCertificate column is True - needed when the target SQL Server presents a self-signed certificate.
  • The credential referenced by CredentialKey must have blank username and password fields. Windows Authentication uses the identity the Change Tracker agent/proxy service is running as, not a stored SQL login.
  • Port and AdditionalParameters are ignored for this scenario.
Example result in the Edit Device dialog:
3. Oracle - direct connection
Used when DatabasePlatform = Oracle and DirectConnection = True.
Server=<IPAddress>; Port=<Port>; Direct=True;
4. Oracle - TNS connection
Used when DatabasePlatform = Oracle and DirectConnection = False (or blank).
Data Source=<DBName>
  • DBName holds the TNS alias as defined in the tnsnames.ora file on the machine resolving the connection (typically the proxy agent).
  • IPAddress and Port are ignored for this scenario - the TNS alias resolves the actual host/port/service internally.
CSV field reference
Column Required Applies to Description
ProxyAgentName Yes All Name of the existing Change Tracker agent that will proxy this database.
DeviceName Yes All The device name to create in Change Tracker.
DBName Yes All Meaning varies by scenario - see below.
IPAddress Yes All Meaning varies by scenario - see below.
Port Conditional SQL Server standard, Oracle direct Database port. Ignored for Windows Auth and Oracle TNS.
CredentialKey Yes All Name of an existing Change Tracker database credential. Must be blank username/password for Windows Auth.
ConnectionCredentialType Yes All V1 (Legacy) or V2. V1 ignores DatabasePlatform and ConnectionString entirely.
TrustedConnection Yes All True/False - passed through to the API’s TrustedConnection field (distinct from Windows Auth; check your platform’s requirements).
DatabasePlatform Yes (V2 only) All SqlServer, Oracle, or other supported platforms.
GroupNames Yes All Pipe-separated list of group display names, e.g. `test1
DirectConnection Conditional Oracle only True = direct connection, False/blank = TNS connection.
AdditionalParameters No SQL Server standard only Extra connection string parameters appended verbatim.
WindowsAuth Conditional SQL Server only True = Windows Authentication connection string.
TrustServerCertificate No SQL Server + WindowsAuth=True only True appends TrustServerCertificate=True;.
DBName and IPAddress meaning by scenario
Because these two columns are reused across scenarios, their meaning changes:
Scenario IPAddress means DBName means
SQL Server standard Server IP/hostname Not used in connection string (used as IPv4/HostName in the API payload)
SQL Server Windows Auth Server IP/hostname (Data Source) Catalog/database name (Initial Catalog)
Oracle direct Server IP/hostname Not used in connection string
Oracle TNS Not used in connection string TNS alias (Data Source)
Sample CSV with one SQL Server (Windows Auth) row and one Oracle (direct) row:
Prerequisites
Before running the script, confirm:
  1. gen7-utilities.ps1 is in the same folder as add-sql-proxied-devices.ps1.
  2. Each ProxyAgentName already exists in Change Tracker as an agent capable of proxying (CanProxy=True).
  3. Each CredentialKey already exists as a Database credential in Change Tracker. For Windows Authentication rows, this credential must have blank username and password.
  4. Each group listed in GroupNames already exists in Change Tracker. The script resolves display names to internal names but does not create missing groups.
  5. You have Change Tracker admin credentials to run the script with.
Running the script
  1. Place add-sql-proxied-devices.ps1, gen7-utilities.ps1, and your completed add-sql-proxied-devices.csv in the same folder.
  2. Open PowerShell and navigate to that folder.
  3. Run:
    .\add-sql-proxied-devices.ps1
  4. When prompted, enter:
    • The Change Tracker host URL (e.g. https://192.168.1.1/api)
    • An admin username
    • An admin password
  5. The script processes each row and prints progress, then a final summary.
Verifying results
After the script completes, confirm the devices in the Change Tracker UI:
  • The device list shows each new database device with its assigned group(s):
  • Open each device’s Edit dialog to confirm the connection string matches what you expected for that scenario (see the screenshots in the “Connection string scenarios” section above).
Troubleshooting
Symptom Likely cause
ERROR: Proxy agent '<name>' not found. Skipping row. The ProxyAgentName doesn’t exist, is misspelled, or the agent isn’t proxy-capable (CanProxy=True).
ERROR (Bad Request) with a JSON body The API rejected the payload - check the printed JSON for the specific field. Common causes: CredentialKey doesn’t exist, a group in GroupNames doesn’t exist, or the connection string is malformed for the platform.
Windows Auth device fails to connect (after successful registration) Confirm the credential has blank username/password, and that the Change Tracker agent/proxy’s Windows service account has access to the target SQL Server. Consider setting TrustServerCertificate=True if the server uses a self-signed certificate.
Oracle TNS device fails to connect Confirm the TNS alias in DBName exists in the tnsnames.ora used by the proxying agent, and that the agent can resolve it.
Rows silently use the wrong connection format Double-check DatabasePlatform, DirectConnection, and WindowsAuth spelling/casing - the script matches the literal string "True".
Related files
  • add-sql-proxied-devices.ps1 - main script
  • gen7-utilities.ps1 - shared helper functions (host/session handling); edit this to set defaults if desired
  • add-sql-proxied-devices.csv - sample/template CSV; copy and edit per deployment
add-sql-proxied-devices.csv (310 Bytes)
gen7-utilities.ps1 (2.5 KB)
add-sql-proxied-devices.ps1 (13.7 KB)
