Automatic Cleanup of DLP Matches on Resource Deletion
Add a foreign key from SA_FSDLP_Matches to SA_FSAA_Resources with new trigger-based cleanup to automatically handle DLP match deletions when resources are soft-deleted.
Problem: Previously, when resources were deleted or mitigated in SDD, related DLP match data wasn’t automatically cleaned up. This required manual execution of FS_SDD_DELETE job which added maintenance overhead.
Solution: Introduced a new FK (SA_FSDLP_Matches ([HOST],[FileId]) → SA_FSAA_Resources ([HOST],[ID])) and created a trigger (TR_SA_FSAA_Resources_UpdateDLP) to automatically delete related rows from SA_FSDLP_MatchHits and SA_FSDLP_Matches when a resource is soft-deleted.
Reasoning: This ensures consistency between resources and their related DLP matches without requiring manual intervention, reduces operational burden, and eliminates risk of stale or orphaned data.
Why best solution: Using a database trigger keeps cleanup logic close to the data, ensuring it runs consistently and immediately without relying on external jobs or scripts.
Manually run the FS_SDD_DELETE job when SDD data has been cleaned up or mitigated.
Upload any other supporting files that you think should be considered in this idea.
3. Create DLP Tables - Fixed.sql (12.8 KB)
