Applicantions, Services, Certifications and Approvals
Hello,
Can ENDpoint Policy manager cover it?
  1. Whitelist software, applications.
  2. Whitelist or manage services.
  3. Whitelist or manage certificates.
  4. Deny access to all security settings such as Windows firewall, defender etc etc.
  5. Set some custom things to work only with approvals.
Use case is to limit developer rights on their endpoints from full admin to only what they need for their work.
Thank you in advance.
Your scenario - reducing developer rights from full admin to only what’s needed is a good fit for Endpoint Privilege Manager. You can remove local admin rights and selectively elevate specific apps, scripts, or tools.
Suggest starting from this link: Netwrix Documentation
Then take a look at this deep-dive into what’s possible with Endpoint Privilege Manager, featuring different user scenarios.
Hello Sal,
Thank you for your reply. But link to documentation is not really a reply, isn’t it?
It’s rather go figure your self answer.
It’s very important to understand if NETWRIX can cover all 5 things mentioned earlier.
Can anyone elaborate on this in detail?
Totally understand where you’re coming from. Community reply aims to share direction and experience rather than full support, but I’ll gladly expand a bit:
From what I’ve seen, Netwrix PolicyPak can cover most of what you’re asking.
It’s just Approval-based workflows? That’s not out of the box, but achievable with conditions via Admin Approval. Netwrix Documentation
The link I shared gives real-world examples from users who’ve implemented similar controls - worth a look for practical context.
Let us know if you’re trying something specific and hit a wall - happy to help troubleshoot.
