Allow non-admin users to switch investigation source (NTP vs NTM)
Enable role-based permission for non-admin users to switch between NTP and NTM data sources during investigations.
Currently, only Admin or Threat Responder roles can switch the investigation source (e.g., from NTM to NTP), even though this action is read-only and does not modify any data. This creates a limitation for organizations where multiple teams (e.g., audit, security analysts, reporting teams) need access to different data sources for investigation or reporting purposes but should not be granted elevated permissions.
As a result, customers are forced to either over-permission users (granting admin-level access unnecessarily) or restrict their ability to access relevant data, which impacts usability and operational efficiency.
A more flexible approach would be to introduce a role-based permission that allows users (e.g., Reviewer role) to switch investigation sources without granting full administrative rights. This would improve security posture by avoiding over-permissioning while enabling broader and more effective use of the platform for investigation and reporting use cases.
Currently, users who require access to different data sources are unable to switch the investigation source unless they have elevated permissions. As a result, they need to rely on users with higher privileges to access or extract the required data, or use accounts with broader permissions than necessary.
Thanks for the submission! This is a good one, and definitely an oversight as you mentioned it requires over permissioning to accomplish.
I’ve tracked this one with the development team, will report back when we have some timeline on when it can be delivered.
Thanks Kevin, appreciate it and looking forward to the next updates.
Discussed this one with the team, and it’d help to get some clarification on their use case. Are they swapping from NTM database to NTP or are they swapping from 1 NTP database to another NTP database?
Are they using out of the box investigations or custom investigations?
Hi Kevin, responding your questions:
Q1: Are you swapping from an NTM database to NTP, or from one NTP database to another NTP database?
A1:We are swapping from NTM to NTP. In order to swap, you have to be a response manager or administrator
Q2 Are you using out-of-the-box investigations or custom investigations?
A2. Both, it is the same result.
