Adjust DPI Allowlist for macOS endpoints | Endpoint Protector
Adjust DPI Allowlist for macOS endpoints to have possibility exclude traffic from scanning by Network Extension
Hi everyone!
We want to share the idea that we’ve used in a real-based customer’s case.
The idea is to have the possibility to exclude some resources in the DPI Allowlist not only from the DPI engine but for the macOS Network Extension (when Intercept VPN option is ON in the EPP settings) as well, so the traffic from specified resources will not be interrupted, and in result, scanned at all.
This feature should help in cases when required resource cannot be reached due to network configuration if macOS Network Extension interrupts the traffic.
We already have experience when the test EPP build with helped with such an issue, and that is why we want it to be implemented in the official release.
At this point, we wanted to add that it would be perfect if this function will work not only with the IP range, but with the domain names as well.
Regarding the domain names, in this case we would suggest taking a look at adjusting the macOS EPP client to add the script what will do DNS resolve and then pass the resolved IP to the network extension level.
As I’ve already mentioned, the test EPP client build with this option already helped with the issue of resource accessibility.
Hi Danylo,
Thank you for submitting your idea!
We’re excited to share some great news here!
As part of our ongoing efforts to enhance our functionalities, please note that our team is already working to facilitate IP Allowlisting from the Network Extension. This development is well underway and scheduled for inclusion in our upcoming releases. As we continue to make progress, we will provide updates soon.
Kind Regards,
Simona
Great suggestion — fully support this idea. Implementing DNS resolution for domain-based entries is especially valuable, as relying on static IPs isn’t reliable for many modern services with dynamic addressing. Automating the resolution process at the computing layer (macOS EPP client side) ensures the Allowlist stays accurate without requiring manual updates every time a service changes its IP. This would significantly reduce operational overhead and improve reliability.
Hi Andrew,
Welcome! We’re delighted to have you with us and appreciate the valuable perspectives you bring to this discussion.
Stay tuned for further updates on this matter as we progress towards it.
Cheers,
Simona
Hi Danylo, Andrew,
I hope this finds you well!
We’re excited to share that you can now allowlist IP’s directly within the Network Extension! This new capability is available in the latest Netwrix Endpoint Protector 2511 Client & Enforced Encryption release.
You can read the full release announcement here: https://community.netwrix.com/t/endpoint-protector-2511-client-enforced-encryption-released/117986
We hope this enhancement brings you great value and we’d love to hear your feedback!
All the best,
Simona
