Add Option to Control Data Transfer Direction in CAP “Block Access to All Storage Devices” Policy
Allow administrators to configure data transfer direction (outgoing, incoming, or both) when applying the “Block access to all storage devices” CAP policy.
Currently, when the “Block access to all storage devices” option is enabled in the CAP policy, data transfer is blocked in both directions — from Local → USB and from USB → Local.
However, in most DLP use cases, the primary goal is to prevent data exfiltration (outgoing transfers from the local system to external media), not data import.
It would be very useful to have a configuration option that allows administrators to define the transfer direction (e.g., outgoing only, incoming only, or both directions). This would provide more granular control over device usage and align better with standard DLP deployment practices.
Adding this feature would also make CAP policies more flexible and adaptable to different organizational security models.
Currently, there is no direct way to allow one-way transfers. We must choose between fully blocking or fully allowing storage devices, which limits our ability to tailor policies to specific business needs. Adjusting the File Tracing Direction in Global Settings does not affect this behavior, so a more precise policy-level control is required.
Hello KimDongHyun,
Thank you for reaching out and sharing your request.
At the moment, there isn’t a specific “Block access to all storage devices” option within the Content Aware Policy. I completely understand the scenario you described; however, we won’t be proceeding with this enhancement right now as we’re focusing on other high-priority items.
That said, there’s a potential workaround that might suit your needs:
If you navigate to Device Control → Global/Computers/Users/Groups Rights, you’ll see that there are several levels of access available for USB Storage Devices. You might consider setting the device rights to “Read Only Access,” which might effectively address your use case.
Please feel free to explore these options, and don’t hesitate to let us know if you need further assistance.
Kind Regards,
Simona
