Add Individual Jobs from the Instant Solutions Library
It would be nice to be able to select which job(s) out of a solution get added from the instant solutions library instead of it adding the entire module.
Currently, when using the Instant Library to add an instant solution, it pulls in the entire solution instead of a having a mechanic to allow for specifying which jobs in the module to add to the console.
Currently, we work around this by manually moving the jobs from the %SAInstallDir%InstantSolutions directory into the Jobs folder for use.
