Upgrade MongoDB 4.0 to 8.0 for Privilege Secure for Discovery
Netwrix Privilege Secure for Discovery (NPS-D) 26.09.0 is the bridge release for moving existing deployments from MongoDB 4.0 to MongoDB 8.0. MongoDB 8.0 is now the standard database for new NPS-D installations.
Action required: If your deployment still uses MongoDB 4.0, upgrade to NPS-D 26.09.0 and complete the migration to MongoDB 8.0 before upgrading to any future NPS-D release that requires MongoDB 8.0.
The video below provides a short visual overview of the single-node migration. For the commands, prerequisites, stop conditions, and recovery guidance, always use the complete official procedure linked below.
This video uses an AI-generated narration voice.
What this means
- New NPS-D 26.09.0 installations use MongoDB 8.0 by default.
- Existing single-node deployments and three-node replica-set clusters can use the guided, side-by-side migration included with NPS-D 26.09.0.
- A future NPS-D release will update the backend to Python 3.13 and supported library versions. As part of that platform update, MongoDB 8.0 will be required, and MongoDB 4.0 will no longer be supported.
NPS-D creates a separate MongoDB 8.0 target, copies and validates the data, and switches the application to MongoDB 8.0 during a planned cutover.
Why this matters
Moving to MongoDB 8.0 gives NPS-D a current, supported database foundation. This platform change supports ongoing security maintenance and prepares NPS-D for platform improvements, and future product development.
What you need to do
- Upgrade your deployment to NPS-D 26.09.0.
- Follow the official procedure to migrate the database from MongoDB 4.0 to MongoDB 8.0.
- Validate NPS-D on MongoDB 8.0 before upgrading to a future release that requires MongoDB 8.0.
Complete procedure: Upgrade MongoDB 4.0 to 8.0
If you need help planning or performing the migration, contact Netwrix Support.
Required before future upgrades
Important: This migration is mandatory for every deployment that still uses MongoDB 4.0 before it upgrades to a future NPS-D release that requires MongoDB 8.0. Complete and validate the migration on NPS-D 26.09.0 first.
Deployments that remain on MongoDB 4.0 will not meet the requirements for releases that require MongoDB 8.0. Completing the migration is necessary to continue upgrading on the active NPS-D release line and benefit from the new capabilities, bug fixes, security updates, library and dependency updates, and platform improvements delivered in later releases.
Need help?
| Situation | Action |
| If you have a question you’d like to ask other experts… | Create a discussion in the community: Privilege Secure > Discussions & Questions |
| If you have a feature request… | Let our product team know directly: Privilege Secure > Ideas |
| If you have something cool to show… | Show everyone what you built: Privilege Secure > Show & Tell |
What are your thoughts?
