Solving netwrix event 2009 connection error
Hello,
I have a problem with Netwrix auditor 10.8 . When i try to add windows server into user activity monitoring plan, then it shows event id 2009 like:
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond IP_addr:445
Could you please, help me for solving this problem.
Thank you!
Hello Elmira,
Welcome to the Netwrix Community! I’ll do my best to try to help you resolve this today.
Typically that error message is going to mean that there is a firewall issue blocking the ports that Netwrix Auditor is trying to use to connect to the Windows Server.
Here is an article you can use to check the ports for User Activity.
User Activity Ports | Netwrix Product Documentation
If this doesn’t work, please let me know. If needed, we can open a support ticket for you.
Michael Purdin
Manager, Technical Support Engineering
