Restore Option for Documents
Is there a way to recover attached files? Currently, files are simply deleted. You are asked whether you really want to do this, but if you confirm, the file is irrevocably deleted. You are also not notified that this document was linked to a password. These documents, such as license files, key files, etc., are extremely important. A recovery option would be extremely important here.
Hi :waving_hand: thanks a lot for sharing your feedback and suggestion… that’s a great idea! You’re absolutely right that being able to recover deleted files such as license or key documents is very important.
At the moment, once a file is deleted, it’s removed. Period. However, we’re already planning to improve this by extending the existing “bin” functionality The plan is to make it possible to recover other object types, including documents, in the future.
We really appreciate your input — it helps us make the product better! I’ll keep you posted here.
Cheers,
Sascha
Hello Sascha, thank you for the Information. Is there a schedule for when the feature will be implemented? That would be important information.
Hi Bernd - I don’t have detailed timeline information yet, but I’ll share updates here as soon as they become available!!
Cheers,
Sascha
