Persistent proxy configuration
Keep the proxy configuration for cloud data sources after product update/upgrade.
At present time there is no built in way to make the Entra ID, SharePoint Online, and Teams proxy configuration to persist automatically across an upgrade.
The best solution is to make this components aware of the system proxy defined on the server host where Netwrix Auditor is installed.
Another solution can be to ask to the user, that execute the update/upgrade, to provide the proxy configuration information (if any) at install time and automatically create the correct XML configuration for these components.
I manually update about ten configuration files with the risk to mess up something…
Thank you for your feature request — this is indeed a valid point. I’ll make sure to raise this issue with our Product Manager.
Thank you in advance for your patience.
