Pardus OS Compatibility
We are requesting official support for the Pardus operating system in Netwrix Endpoint Protector.
Pardus is an open-source, national Linux distribution based on Debian 12, widely used across public institutions in Türkiye. It is particularly preferred by government agencies, municipalities, and organizations in the defense and military sectors, and its adoption continues to grow.
The Netwrix Endpoint Protector agent can technically be installed on Pardus, since it is based on Debian 12. However, when the Content Aware Protection module is enabled, the system completely freezes and becomes unresponsive until a reboot. In fact, even an empty policy (with no content filters defined) is enough to trigger this issue. As a result, it becomes impossible to test or deploy the product in environments where Pardus is used.
This limitation has already become a significant blocker in several ongoing public sector projects that are currently in evaluation or procurement stages.
Providing official support for Pardus would strengthen Netwrix’s position in the Turkish public sector and offer a serious competitive advantage—especially as some alternative solutions in the market already support Pardus environments.
Since the agent either cannot be properly installed or does not run stably on Pardus, we are currently unable to provide any workaround or solution for this issue.
Hi Faruk,
Welcome to Netwrix Community!
Please allow us some time to investigate your request by assessing our existing capabilities and identifying any technical requirements to accomplish this.
We will get back to you with a response as soon as we have updates.
Thank you,
Simona
Hello @faruksari,
We’re happy to share some exciting news with you!
Our team has successfully completed the development and validation of the EPP Client for Pardus OS. This means you can now benefit from full EPP functionality on your Pardus-based systems.
To get access to the Pardus-compatible client, simply reach out to our EPP Support Team. They’ll be more than happy to provide you with the installation package and assist you with any setup or configuration guidance you may need.
We truly appreciate your interest and engagement, and we’re glad to deliver a solution that better supports your environment. Thanks again for being a valued part of our community!
Kind Regards,
Simona
Hello @simona.lazsadi,
Thank you for the great news and for addressing this request so quickly.
We appreciate your support and efforts in providing Pardus compatibility.
Best Regards.
