Option To Save Endpoint Protector Client Installation Settings
Endpoint Protector Server
Unable to save Endpoint Protector client configuration settings after few recent upgrades
In previous versions of Endpoint Protector, we were able to save the client configuration details within the “Client Software” field. However, since the last few upgrades and migrations, this setting no longer saves.
Every time we generate a new client installation package, we now have to manually re-enter the details (Endpoint Protector Server IP, Endpoint Protector Server Port, and Department Code).
Could you please restore this feature back to the Endpoint Protector.
Let me know how to permanently save this configuration for future package deployments?
It seems to be working fine up to Server version 2604.0.1.0.
I have a question for the person in charge reading this.
Is there a way to change the default value for the “Endpoint Protector Server IP” setting from an IP address to a domain name?
I tested this on both Windows and macOS with server version 2608. The settings entered on the Client Software page are preserved correctly in the generated Client Package. The fields on that page do revert to default display values once you navigate away, but this is a display behavior only and doesn’t affect what’s packaged.
Domain names are also supported.
Best regards,
Zoran
@Zoran It seems the issue for User @WILLIAM LAU is that the default display value is not being saved.
My question is how to change the default display value.
@devpark If the value is not saved, it means that it’s a server glitch that is worth investigated by the Technical Support team.
In regards to changing the default display value, I am afraid that is not possible, it will revert back to the server’s IP/FQDN.
Thank you for looking into this matter. Some time ago on 5.9.x.x firmware version before it becomes 4 digits (2510.x) version releases. I was able to save and keep the server display value (FQDN) and continue to use it on client package generation process.
