Option to clean up / automatically remove decommissioned agents from System Health
Ability to automatically clean up or remove decommissioned agents from the System Health view to maintain accuracy and reduce noise.
Currently, the System Health view retains agents associated with decommissioned systems (e.g., old domain controllers), even long after they are no longer active. This results in cluttered views, reduced visibility into actual issues, and unnecessary confusion during monitoring. In environments with frequent infrastructure changes (e.g., hardware refreshes), the number of inactive agents can grow quickly.
This feature would introduce the ability to automatically remove or archive decommissioned agents based on configurable criteria, such as inactivity over a defined period or lack of recent events. Optionally, administrators could trigger manual cleanup or define grace periods to avoid accidental removal. This would ensure that System Health reflects only relevant, active systems and remains a reliable source of truth.
Currently, decommissioned agents are managed manually by identifying and attempting to remove them from the System Health view. This process is time-consuming and carries some uncertainty, which often results in outdated agents accumulating and reducing the overall clarity of the dashboard.
Thanks for the submission! This is something we can definitely tackle. We’ll make it so that after 7 days of inactivity after being decommissioned the agent will be hidden from the page.
Hoping to deliver this in Q2 timeframe.
Great update, thank you!
