Online Training - Pick and Choose
Is there any way to bypass the prerequisite requirements for the training modules so that you can choose which ones you want to review? I am not trying to get certified, I just want to see if this training provides more detail than the documentation does. I don’t want to be forced to go through every piece of it.
For example. I want to see what is included in the reports module but I can’t because I have not completed everything before it. My Installation, configuration, and Monitoring Plan setup is already complete. I want to be able to just review the parts relevant to me.
Thank you for raising this concern. Your feedback is appreciated!
Our intent is for customer training to be flexible and allow you to access only the modules that are relevant to your needs. The behavior you encountered was not by design. The course was recently updated using a new format, and the enforced prerequisites were an unintended side effect of that change.
We have reverted the course to the previous version, so you should now be able to access the Reports content in Module 2 directly without completing the earlier module. We will ensure this issue is addressed before the new format is reintroduced.
Thank you for taking the time to share your experience. Your input helps us improve the training experience.
Thank you for your quick response and action.
