Netwrix Threat Manager Reporting Module - Archive Data
Is there a way to view data that has been archived/moved to archive DB in Netwrix Threat Manager Reporting Module like you can with the NTP console?
Hi Justin,
You should be able to add the archive database as an integration for NTM reporting just as you would for the active NTP database.
Okay great, we will give it a try. Thank you!
