Netwrix Privilege Secure for Access Management
Hello everyone, we are encountering issues with a client. Some actions remain pending, as shown in the attached image.
What can we verify? At present, we have: Restarted the machine services Re-registered the services Restarted the machines
Additionally, I notice that the secondary has this:
We eagerly await your response. Thank you, Giacomo.
Hey Giacomo,
I’d recommend checking the ActionServiceWorker log on both application servers for token refresh errors. If you find any re-register the services on that server. If that doesn’t help I’d recommend opening a support ticket in our portal at netwrix.com so our team can take a look. What version of NPS are you running currently?
Hello,
As you suggested, there are some errors in the actionserviceworker.
I also noticed in the proxy section:
Thank you.
Hi Giacomo,
Can you please open a support ticket so our team can investigate the environment?
- Dan
The errors you are seeing indicate that the host does not have an Internet connection and the CRL check for the certificate is causing the handshake to timeout. There is a KB article that can help with this.
Speeding up CRL Checks on SbPAM Servers without Internet Connectivity
HTH,
-Kevin
Good evening everyone,
We have resolved the issue. We powered down both machines, rebooted only the primary one, re-registered the service as localhost, and waited for the services to come back up. We then performed the same procedure on the secondary machine.
Thank you all for your support,
Have a good evening,
Giacomo.
Glad to hear things are working now! We appreciate the update :+1:
