How does Netwrix Auditor determine the number of licenses being used in Entra ID? Is there a script I can run to find out how Auditor is doing this?
Hi @badeans_ssc, the number of licenses is defined by enabled Entra ID users, except for those you omitted using omit list. You can refer to this article for more info: Netwrix Auditor Licensing FAQs
Hi Dmitry. Will the number of used licenses be reduced by the number of accounts in the omit list?
Yes, it will, if you use omitUPNlist.txt as described here Microsoft Entra ID Monitoring Scope it’s a relatively new functionality, added about 6 months ago.
