Netwrix Account Lockout Examiner
End account lockout issues for good
Account lockouts always happen at the worst time, resulting in expensive downtime and frustrated employees. Instead of combing through confusing event logs, get instant insights so you can remediate quickly. Whether it’s stale credentials, forgotten service accounts, or broken mapped drives, Netwrix Account Lockout Examiner identifies the root cause in a single click.
One-click root cause analysis
Enter a username, click investigate, and instantly see what’s causing repeated lockouts without digging through logs.
Instant lockout diagnosis
Cut troubleshooting time by 90% with immediate insights into stale credentials, services, and device issues.
Simple deployment
Run directly from any workstation without complex deployment or installation on user desktops.
Help desk intelligence
Give your service desk team the intelligence they need to resolve lockouts fast and reduce escalations.
Account lockout investigation made simple
Instant cause identification
See exactly what is causing a lockout, whether it’s mapped drivers, services, tasks, or mobile device passwords.
Visual lockout map
Get straightforward mapping of lockout sources and patterns across your Active Directory environment.
Easy remediation steps
Receive specific guidance and actionable steps on how to fix the root cause of your lockout issues.
Multi-domain support
Investigate lockout across domains and forests from a single interface with a hassle-free installation.
Technical Requirements
  • Operating System: Windows 8.1 or above
  • Required Component: .NET Framework 4.5
